Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Position representation from Inventor, multiple callout, precise align
2 REPLIES 2
1021 Views, 2 Replies
- exist some vay to use existing positional representation from Inventor?
- is posible to add more than 1 associate property to callout/annotation?
- how i can precise align 2 objects, not draging by Move command (in example i have imported medels from 2 diferent sources and i need align this components by their axis)
Lubos Petr
Dagis a.s.
2 REPLIES 2
AlexFielder
Unless I'm mistaken, these points should answer your questions:
1. The best way of using Positional Representations (Pos. Reps.) in Publisher is to first export the assembly to the .dwf format, grabbing all Pos. Reps. in the process.
2. I don't think this is possible, although I haven't tried it..
3. I think you'll likely have to do this within Inventor, and then either insert the assembly into Publisher, or export to .dwf and then insert (If you want to keep/use Pos. Reps.)
in reply to: AlexFielder
Hello there
I'm testing the trial of the 2012.
Is there a solution in the 2012 version, to use  Positional Representations (Pos. Reps.)?
Need to to a complex mobile manuals, which would be easy if I could use PosReps.
But without, I don't really see the use to pay so much for the Publisher.
Kind Regards,
Andreas
