'S' shaped broken view for shafts
When creating a broken view on a long shaft, the two options available are Rectangular or Structural which is fine for rectangular shaped parts, but would be nice to have an option to create the 'S' shaped broken view for round parts like long round shafts, see attachment
33 Comments
dan_szymanski
Robert.Reid
Shaft Break in the Drawing Environment
Curtis_W
dan_szymanski
Status changed to: Gathering Support
Thanks Curtis - You took the words right out of my mouth. This idea has already been submitted and is a duplicate. Please be sure to cast your kudos to the master Idea. http://forums.autodesk.com/t5/Inventor-IdeaStation/S-shaped-broken-view-for-shafts/idi-p/3793222
dan_szymanski
Status changed to: Accepted
Accepted idea [469]. Thanks!
Latikman
Community Visitor
What's the progress regarding this "S" shaped Break profile/style intended for cylindrical objects? is there any available update yet for inventor 2014? its always a problem on my part when drawing long shaft, pins, etc and using the available Break style (symbol is intended for sheet metals,square shape objects etc), in our production area, our machinists and even my bosses complain on this because it is not standard break symbol for cylinders and I cannot use the reason "That there are only two available symbols available on the drawing software I am using" they will just tell me if "Can the software provider create a solution for this simple problem considering  how expensive this software is" I can't blame them for they are the one who have paid for this software. I draw a lot of shafts, Pins,Bolts,pipes,etc. So I use this Break Command alot in my Drawings. please reply.
When breaking a view of a round object in AutoCad, I have always seen the break terminators as a spiral.  Would it be possible to get this terminator style added to Inventor's "Break" view  at some point?  I did some searching and couldn't find anything related to this, so here's hoping it's a new idea instead of rehashing old news.
Here is a picture of what I mean:break graphic.png
madviking
Observer
I have always felt this was a huge oversight on Autodesk's part. I have never seen round objects broken without using the spiral type terminator. Please implement this asap!
DRoam
Autodesk has be very, very sluggish to implement this. Multiple requests for this have been made and they've all received dozens and dozens of votes, and one of them has even been "Accepted" by Autodesk since early 2013 (2 and a half years ago)... and there's still no sign of it being implemented.
If you want to try and make your voices heard a little more, go to the following similar requests and give them a Kudo as well.
Imagine if Autodesk had used its time to work on and implment this rather than the cute, questionably useful Home Screen...
ian
As a design engineer, who on a daily basis draws/designs long shafts, I find it difficult to understand why Autodesk continue to overlook this. Surely this is an easy one for the software designers.
I have recieved 100+ kudos from the community regarding this, but clearly our ideas put forward fall on 'deaf ears' Do Autodesk actually look at our ideas???
mflayler
Your idea was Accepted.  That means that is currently in planning development and out of the Under Review stage.  Some ideas cannot be implemented quickly and some ideas are not internally rated higher than others in development.
Any update on this feature please?
ian
'S' shaped broken view for shafts, This was posted 4 years ago, and still nothing done was hoping it would be added to 2018, neither is spell checker.
So far very disappointed with the upgrade.
dan_szymanski
Idea added to backlog for future consideration [469]. Thanks!
need to send out better looking drawings thanks
ian
Very true, but I doubt a better looking drawing will accelerate the change anyway 🙂
ian
MikeKovacik4928
See my post for my  workaround to this.
https://forums.autodesk.com/t5/inventor-forum/pipe-break-appearance-in-idw/m-p/7731357#M679382
I didn't realize this idea had been posted twice when I made my post.
It does seem a great pity this idea  has not been implemented when it has been requested so many times
and had so many votes!
I will definitely add my vote now
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
Cabasho
I was about to post this suggestion... it is critically needed as the software wont even let you "hide" the break line to add the right one as a sketch. This was posted back in 2013... we are in 2018 now and it is still not implemented... please add it.
Also I should add... this is one of the top voted ideas....
ian
