- Mark as Read
- Email to a Friend
- Printer Friendly Page
Item Number from Parts List as an Available Property
Status: AcceptedHere's one that I've had requests for several times.
You have an assembly view on a drawing and place a parts list for that view. Now, you want to place several base views of individual parts for detailing. Along with each part view, you want the corresponding item number from the parts list.
I know you can edit the view label to include model properties, such as the part name, material, etc, but there's no way to link the item number from the parts list to that part. It would be nice to link that part to the corresponding item number in the parts list and if the parts list is renumbered, the item numbers associated with each part view would update accordingly.
I've tried placing a balloon and selecting the individual part, but it will only use "1" as the item number, since it is just a component and not an assembly. Perhaps, when adding a balloon to a part like this, you could select the parts list that you want to reference. Many times, you may have several sheets of details and still want the item numbers to reference the parts list on sheet 1, where the main assembly view and parts list is located.
- Mark as Read
- Highlight
- Email to a Friend
The Bill Of Material editor has had the Item number in it since it was introduced...
If you really wanted to fill in the item No. at the model stage then us a custom I Porperty.
- Mark as Read
- Highlight
- Email to a Friend
This does not do what I am describing. I want the ITEM column in the Parts List to be a property that can be added in a string of text or in the view label. If I do what you suggested, the renumbering of the parts list does not update the user property.
- Mark as Read
- Highlight
- Email to a Friend
YES! It's the little things like this that would make it better.
- Mark as Read
- Highlight
- Email to a Friend
Include quantities while your at it. Some shops arn't manufacturer's, they're fabricators. Fabricators need to be able to reference the quantity of a part in a particular assembly in the part's detail. Right now I have to use a convoluted error prone reach around to accomplish this.
- Mark as Read
- Highlight
- Email to a Friend
Yes, this would be a great feature to have. I have seem many drawings go wrong due to the lack of this feature. People just tent to add this information manually, witch in many ways is asking for problems. Same goes for 'text' parameters, it would be awsome to be able to use them in an idw as well.
- Mark as Read
- Highlight
- Email to a Friend
My company is one of the "fabricator" types, and something like this would be extremely useful for us. I've been looking into some iLogic code that achieves this, but it would be great if this were built-in functionality for at least weldment assemblies.
I've read several discussion threads about similar ideas, and one common question that comes up is "What about parts used in multiple assemblies?" I see two ways of handling this issue:
1) The situations where people want to use this are often in cases where the parts won't be reused anyway (frame components, fabricated steel plate structures, etc). It could probably do what most people would want it for, even if it only worked for a single assembly.
2) The item number and/or quantities could be inserted into the part file as custom iProperties, and the names of the properties could include the name of the governing assembly, ex. "ASSY-12345 ITEM#" and "ASSY-12345 QTY". The user would then simply have to pick the relevant assembly's property when inserting the information into view labels, notes, etc.
- Mark as Read
- Highlight
- Email to a Friend
- Mark as Read
- Highlight
- Email to a Friend
- Mark as Read
- Highlight
- Email to a Friend
And......Please add "View Reps" and "Position Reps" as an option to the view label.
Accepted idea [US14620]. Thanks!
