location of views in different sheet
Hello
views such as section ,detail , etc. can be moved to different sheet
In this view the location of the "Master" view can be add easily (from the text dialog box)
for example , the views move from sheet 1 to sheet 3
I want to add the location of the views in the master view label (without ilogic)
regards
7 Comments
Adding to the drawing view labels referencing the parent sheet index, you could add a reference to the border localisation. Also, you could apply the same idea on the view definition to refer to the location of the view itself.
Ex.: you have a detail view A on page 2 that is based on page 1. The view definition is located on page 1 at row C column 3 (on the border). That way, the title of Detail A on page two would read "Detail A (1,C-3). And you could apply the same type of address on the view definition to refer to where the detail view is located on page 2 (ex.: 2,B-2).
We already did that as an in house addon, but it is hard coded to our needs and is not customizable, witch is not in the Inventor mentality, but for a custom addon it was. So basicaly what I did was to locate the coordinates of the label of the view and apply a simple calculation to know in witch column and row it end up. We always use the same format of paper and the same border, so it worked out for us.
I have attached a jpg to illustrate. Notice the address of the "to" where the section view G-G refers to and the "From" where the Detail F was taken from.
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. The product team continually reviews this forum aiming to
deliver in the most impactful way we can based on voting. We also regularly examine the
list to make sure it reflects the most current Ideas. As part of this process we archive
old Ideas that haven’t received broad support. This ensures there is room for new Ideas
to be reviewed by the community and for the most relevant and meaningful ones to gain
votes.
This Idea is archived because it's been on the board for over a year and hasn't received
many votes. If you want to raise it again and try to gain more support across the
community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups
can help convey concepts and generate more votes from other users. If you have questions
or see a connection between this Idea and others that should be accounted for, please
let us know.
- INV.IdeaReview
RJR89
I assume most people are looking for a variant of the below section label and mark?
reference the parent sheet on the label and child sheet on the mark/line. Leave a dash when both are on the same page?
jingyi.liu
Status changed to: Gathering Support
Noticed that you don't want the function via iLogic, I guess you know than iLogic can do it.
Solved: Is there a child complement to <PARENT SHEET INDEX> ? - Autodesk Community - Inventor
Brad.Headlam
Has any progress been made on this issue?  Some of the threads and requests all chasing the same outcome.
Need this function even more now, as we are using Autodesk Construction Cloud  (ACC) and need to be able to have "sheets" in ACC recgonize Inventor sheet call-outs as ACC can do with sheets upload from Revit.
https://forums.autodesk.com/t5/inventor-ideas/detail-or-section-view-title-show-what-page-the-parent...
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/section-detail-view-label-sheet/td-p...
https://forums.autodesk.com/t5/inventor-forum/section-labels-with-sheet-number/td-p/8652032
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/drawing-view-labels-parent-sheet-chi...
https://forums.autodesk.com/t5/inventor-forum/view-custom-labels-sheet-number/td-p/7065153
INVGEN-60057
Yijiang.Cai
Status changed to: Accepted
Accepted as [INVGEN-60057]
dan_szymanski
This idea has been implemented within Autodesk Inventor 2026. Please review the Inventor 2026 What's New article here, for more information regarding how you may leverage it. Special thanks to everyone who cast a vote for this capability.
