Am I correct that a pipe route, even if the components are in the but- welded style, can't be welded?
When I go to the assembly that holds the cmponents of the routed pipe, the " turn into weldment" icon is grayed out.
I realy hope this is not as inteded, because I need to show the weldsymbols in the drawings.
As far as I know that is correct, but you can add the weld symbols manually in all of your drawings. More work? I don't know since we don't show them on ours. You might consider adding this to the Idea Station for future consideration.
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I could live with the work around that you could take the route and pipe assy and save a copy as a normal assy, turn it into a weldment and replace the original routed one,..... but, this also , again, is not possible.
Also,I need to make a realistic representation in Showcase of a device that has lots of this welded components. Doesn't look good when pipes and elbows are just floating on thin air..
Hi!
Just for showcase... Why don't you export your assembly to STEP... open again in inventor and try to apply weld... just an idea.
You will lose the associativity, but you will win some pretty good images
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
I have not tried it but couldn't you just take the assembly your working on and put the whole thing into a weldment assembly? That way you can still edit that assembly like normal but when you need to show it on a drawing with welds you can just use the higher up weldment.
That is a good tip Carlos,
But that made me think that I better export only the pipe route to STEP and insert it on top of the original, and than making some LOD settings that can be used in Showcase.
The derive tip was good Blair,
so now it goes from pipe route > drived part > make componets> assembly> welded assembly
