Inventor Forum
Scale object
3 REPLIES 3
1188 Views, 3 Replies
Scale object
Hi I made the mistake that I came to measure my object as cm but inventor writes it's in as mm, is there a way where I can scale objectet up giving it the right size
3 REPLIES 3
JDMather
You can go through your Parameters and change all of the dimensions or Derive Component with Scale.
Can you attach the file here?
in reply to: JDMather
Yea here is the object there is two small objects
and thanks for the help so far
here is the other
