Is it possible to make balloons opaque in the IDW environment? I have several instances where the best location for a ballon is over hatched regions or part edges, and the extra lines make the balloon numbers hard to read.
tools..document settings..drawing tab and turn on "cross hatch clipping"
Thanks for the tip. However... it didn't seem to do the trick.
My hatches are contained in a 2D sketch which is linked to the view, with the outlines being projected. My balloons are the default style, with overriden numbers.
Anything else I can try?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I created a sketched symbol with a white fill, and used it to override balloon #9 (from my previous post). Still no luck.
Niels van der Veer
The Netherlands
You are correct. I created a sketch on the view, projected the lines I needed, then manually added lines and arcs to close the profiles. It was a very time-consuming process-not sure if there is a better way? You can see one of my sketch lines (closing a profile) in the bottom left of the image where the two components meet.
I guess "cross hatch clipping" doesn't apply to hatched sketches.. only section view hatching,etc...
another half finished autodesk function.
Niels van der Veer
The Netherlands
