Hi There,
Is there already a official Autodesk whitepaper with the new features in Inventor 2014? Cannot seem to find it anywhere.
Rgrds, Daniël
Solved by jeanie.wayker. Go to Solution.
Solved by MingweiGao. Go to Solution.
Do you want to find this?
http://wikihelp.autodesk.com/Inventor/enu/2014/Help/0000-What_s_N0/0001-What_s_N1
Is there a whitepaper version out yet? Or only the wiki?
I like to print out a white paper booklet to give to my design guys rather than having to navigate a wiki page.
I would also like to see a white paper version.
Autodesk, will this become available? Or is the wiki style the new standard?
Daniël
Hi, The PDF of the What's New exceeds the the file size allowed on the discussion group. I have posted to the wiki. You can find it here at the bottom of the page - http://wikihelp-stg.autodesk.com/Inventor/enu/2014/Help/0000-What_s_N0/0001-What_s_N1#pageFiles
Thank you,
Jeanie Wayker, Autodesk
Hi jeanie.wayker,
Thanks for making the PDF available, I prefer to download and keep the PDF versions of the What's New for reference. Unfortunately the link you provided does not allow me to access the file. Can you provide a revised link?
This is what I get when I follow the posted link:
Forbidden
You don't have permission to access /Inventor/enu/2014/Help/0000-What_s_N0/0001-What_s_N1 on this server.
Apache/2.2.3 (CentOS) Server at wikihelp-stg.autodesk.com Port 80
Would it be possible to add a link at the bottom of the WikiHelp page as you did for 2013:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0000-What_s_N0
Thank you,
Curtis
Hello!
I do apologize! I have been able to save the PDF more efficiently and am attaching now for you to download here. I will also add to the wiki and will provide a good link for you shortly.
Thank you,
Jeanie
The What's New for Inventor 2014 as a PDF is also now available on the wiki here:
PDF is posted at the bottom of the page!
Thank you for your patience. Please let me know of any questions.
Thank you,
Jeanie
This is what I see when I click the link from the wiki:
The wiki appears to be having some issues right now. Please download attached Whats New PDF from this post.
Thank you,
Jeanie
Thank you very much. BTW, The PDF attachement in the wiki DOES appear to be working now!!!
Thank you again,
Jeanie
The WhatsNew_.pdf attached twice above is not the final version.
The WhatsNew_Inventor_2014_.pdf attached here is the final version. Jeanie has uploaded the final version here this morning: http://wikihelp.autodesk.com/Inventor/enu/2014/Help/0000-What_s_N0
Notable differences between two documents:
Glenn
In addition to the What's new in Inventor 2014, is there some information on
What's fixed in Inventor 2014?
I am most specifically interested in finding out if the drawing environment has been fixed to
show arcs and circles to be in fact arcs and circles instead of splines.
Not knowing too much about other issues, that is the one and only thing I've asked back in Rel 2011, 2012.
Found out that 2013 still didn't fix it, I did not even install it.
So can someone please shed some light on wether this is still the case with 2014?
Thank You
Hate to have to be the one to tell you this Glenn and Jeannie, but the link on wiki seems to be broken (again?)....
I just verified that all of the following links work:
HTML version of What's New:
PDF version of What's New:
http://wikihelp.autodesk.com/@api/deki/files/111064/=WhatsNew_Inventor_2014_.pdf
Parent page:
Glenn
