So it isn't a major issue but I know how measure used to show a blue line when measuring between two faces or points that it measured (by default the closest distance) but ever since installing 2014 I no longer see those lines. Does anyone know if that is a setting somewhere or if that was just removed completely?
I still see the line here.
What selection filter do you have active?
I just changed selection types a few times and now it appears. Don't know why it wasn't working but it works now so I'm not complaining.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
Yeah I am using a space navigator running the most recent 3Dconnexion driver so maybe it does have something to do with that.
All,
We've confirmed that we have several "preview" graphics issues.
The issues are new in update-2, and we have been tracking them as DID 1501516 in our product database.
We believe we've identified the cuase and code change have been made in our internal test builds.
Thank you,
-Sami Harada
Inventor Framework QA
Autodesk Inc.
Hurry up to get the hotfix, but it is very inconvenient to do the measurement, easy to make a mistake
I can confirm we're having the issue as well (30+ machines on Update 2). Please fix ASAP as it's crucial for knowing exactly what you're measuring. Imagine being given a tape measure without text on the tape .
I have the same issue. Also when displaying the curvature.
Zooming in will show the line (but then you might not see all the rest...)
