I'm a little stuck using Autodesk, I really want to have my logo engraved into a custom build project...
but the only thing I Know so far is how to add a image file, and how to engrave text.
is it possible to engrave a imagefile into a solid body (like text)
cya
Solved by -niels-. Go to Solution.
im not sure if this is posible, can u post a photo of your logo?
is it hard to re-draw it in inventor so you can extrude it?
greets from holland!
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I couldn't resist, took some cleanup to get it to work properly and the geometry will not be exactly the same but i hope you can use it.
Niels van der Veer
The Netherlands
it worked, used inkscape to redraw it. It was easier than expected so I redisigned it for a bit
