• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    raumpunkt
    license transfer utility for mac does not work
    807 Views, 14 Replies
    10-28-2011 01:02 AM
    LTU does not work with Autocad 2012 for Mac (OSX Lion). It is not possible to export license.
    Please use plain text.
    Product Support
    Re: license transfer utility for mac does not work
    10-28-2011 07:43 AM in reply to: raumpunkt
    Hi raumpunkt;
       Do you receive any error messages when you try to export the license?
    dwayne
    Dwayne Poot
    Support Specialist
    Product Support
    Autodesk, Inc.
    *Expert Elite*
    TravisNave
    10-28-2011 01:21 PM in reply to: raumpunkt
    If you are making a permanent change, simply reactivate your software.  It's less time consuming than figuring out why the problematic LTU never works.
    Please call Autodesk Product Registration and Authorization:
    http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
    1-800-551-1490
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    *Expert Elite*
    DarrenP
    10-28-2011 01:50 PM in reply to: TravisNave
    *Expert Elite*
    DarrenP
    10-28-2011 01:51 PM in reply to: DarrenP
    raumpunkt
    10-30-2011 11:29 AM in reply to: raumpunkt
    no error message. After pressing "export" message is "please wait while exporting"... -and then "export sucess" - but license was not exported.
    Product Support
    10-31-2011 02:48 AM in reply to: raumpunkt
    This is a known Issue with MacOSX Lion and Autocad for Mac 2012. We are working on a fix to this issue.
    Until the fix is released, please activate the license on the second machine using any of the method mentined here
    http://usa.autodesk.com/adsk/servlet/item?linkID=9241177&id=5584421&siteID=123112
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    Autodesk, Inc.
    New Member
    sunithaya
    02-21-2012 01:23 PM in reply to: hashim.mundol
    I have MacOSX Leopard (10.6.8) but the same problem occurs with Maya 2012.  I need to switch between my laptop and my more capable desktop (and back) almost daily As a teacher I use the laptop in class but the desktop in my office. So calling Autodesk to activate on an almost daily basis is problematic at best. Thanks for any help
    philip.s
    02-21-2012 02:43 PM in reply to: sunithaya
    Hi Sunithaya,
    Per the Autodesk Product Activation FAQ, para 5, you are entitled to 2 activations per license (desktop + laptop) as long as the software is used by the same person and both copies not at the same time.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Member
    kevinwkoch
    01-01-2013 01:41 PM in reply to: raumpunkt
    I'm finding that the LTU doesn't work for mac with Maya 2012. It looks like this has been a known issue for quite some time. Is it really so difficult to solve. This is extraordinarily frustrating, especially since I need to do this on a holiday when there is zero phone support and my online class begins tomorrow.
