Unable to uninstall or re-install Revit Architecture which did not install properly
I have recently downloaded Revit Architecture 2013 and have installed it on my laptop. Whenever I try to open it up, it does not open. The computer recognises that it is on my system but it does not open it up. I have tried to uninstall/change Revit Architecture 2013 from the Control Panel but it will not load a uninstall manager. Furthermore, it will not even open up other options when I select uninstall Revit Architecture 2013. I have tried to reinstall the software on a number of occassions. However, when I go through the installation procedures and I get to the stage where I am asked to select which modules of Revit I want to install, no options are available for me to install/change/repair - all the modules are recognised as being on the system.
Solved by aaronhai. Go to Solution.
Please see if this helps: http://usa.autodesk.com/getdoc/id=TS17892584
Hi Aaron,
Your solution says that if youve already done clean uninstall..but what if Revit is still installed and I cannot uninstall/repair or reinstall?
