Installation & Licensing
Unable to install content libraries for Autocad Mech 2010 64-bit on Windows.
3 REPLIES 3
1016 Views, 3 Replies
Hello.
Having an issue installing the content libraries for Autocad Mechanical on a 64-bit Windows 7 machine.  I am logged in as local admin.  During the install it give me this error (Error 1320. The specified path is too long: c:\documents and settings\all users).  If I go into configure the installation to modify the Content libraries under Autocad Mechanical 2010, it gives me this error (C:\Documents and Settings\All Users\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb).  Any ideas?
Tammy
3 REPLIES 3
emily.xu
Mechanical 2010 do not support Windows 7, see: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15458102&linkID=9240897#section3
Also, if you see the error on other OS, please try to move your installation files into a short folder, such as c:\temp.
Emily Xu
Product Support
in reply to: emily.xu
Got it fixed.  Had to change where the Content Center Library was saving to.
I changed it from
to
C:\Users\Public\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb
Also had to either be logged in as local administrator or right click on the install and choose run as administrator.
Thanks!!
Tammy
Have you tried Long Path Tool Program Ever? Its a good one.
Administrator Productivity
