Hello.
Having an issue installing the content libraries for Autocad Mechanical on a 64-bit Windows 7 machine. I am logged in as local admin. During the install it give me this error (Error 1320. The specified path is too long: c:\documents and settings\all users). If I go into configure the installation to modify the Content libraries under Autocad Mechanical 2010, it gives me this error (C:\Documents and Settings\All Users\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb). Any ideas?
Tammy
Solved by tforal. Go to Solution.
Mechanical 2010 do not support Windows 7, see: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15458102&linkID=9240897#section3
Also, if you see the error on other OS, please try to move your installation files into a short folder, such as c:\temp.
Got it fixed. Had to change where the Content Center Library was saving to.
I changed it from
to
C:\Users\Public\Documents\Autodesk\ACADM 2010\ACADM\Gef\Gdb
Also had to either be logged in as local administrator or right click on the install and choose run as administrator.
Thanks!!
Tammy
