• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Salvago
    Stand Alone student license; could not start product
    1725 Views, 2 Replies
    07-12-2011 08:01 AM
    I already posted this problem in the student support section; but to no avail.
    So here again; the gist of the problem:
    Background info: Windows7,
    3ds Max 2011 previously installed(also from the AEC, without problem).
    The licenses mentioned are all stand alone; provided through the Autodesk Educational Community programme.
    This concerns both 3ds Max and Mudbox. First I downloaded Mudbox 2012 and installed with the provided product key, all without problems. However upon trying to run the product before getting the main window I got confronted with a 'environment variable MUDBOX_ALT_EN is not set' error, upon which the application would close.
    Now I tried to fix this by using both the Repair install, and Reinstall options. After that I tried a full uninstall and reinstall, and deleting the adskflex_xxx files in ProgramData\FLEXnet\ (as suggested on the web), but all to no avail.
    After that I Uninstalled mudbox again, and downloaded 3ds Max 2012. I installed the product, again without problem; but this time instead of directly activating the product I opted for the '30-day trial' (also suggested on a forum; so I could atleast use the product until the activation issue would be resolved). However upon running 3ds Max (at the end of the splash loading screen) I receive an error all the same. This time 'The software license check out failed. Error 5'.
    After searching for solutions, or possible causes I found that this error should only occur with network licenses, so I'm rather baffled as to why I'm having it. I've checked and double checked that I am indeed running (,or trying to,) a standalone license, and verified by reinstalling the products multiple times.
    I have found that upon reinstallation of 3ds Max 2011; I had it uninstalled before installing 2012 as I did not expect any issues; it now too gives me the 'The software license check out failed. Error 5' error.
    Is this a known issue? Any suggestions as to what may cause it, and more importantly, how to resolve it?
    -Sal
    Please use plain text.
    New Member
    Salvago
    Re: Stand Alone student license; could not start product
    07-14-2011 11:35 AM in reply to: Salvago
    Please, anybody?
    I really need this software to work; Assignments keep piling up and at this rate I don't know if I'll be able to catch up..
    Product Support
    07-15-2011 05:42 AM in reply to: Salvago
    Please try to delete c:\programdata\autodesk\adlm folder and reinstall all Autodesk 2010/2011/2012 products you are using
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
