Installation & Licensing
Inventor 2014 SP1 closes on splash screen Win 8.1 x64
2 REPLIES 2
1039 Views, 2 Replies
Hi everybody!
I've ran into a quite unique problem with Inventor 2014 Pro on Win 8.1 x64 . I've installed SP1 and even the Update 2, which claim to solve startup problems. Though Inventor fails to start, splash screen launches, loads the bar to the half, then disappears to nowhere, without any error report.
I tried all workarounds I found on the internet, even those which hasn't got exact relations to the problem ( even changed registry), still no improvement. All the other Autodesk tools work fine, even Inventor View.
I found few similar requests for help, but those didn't led to any solutions.
2 REPLIES 2
dembkod
daniel.azim,
Hello. This type of behavior is usually connected to licensing. If this is a Network licensing type, delete the cascadeinfo.cas file and try again. It should be located here:
C:\ProgramData\Autodesk\Adlm
If this is a standalone install, delete the tsf.data file and retry. It is located here:
C:\ProgramData\FLEXnet
Thank you for taking part in our community!
David Dembkoski
in reply to: dembkod
Dear David Dembkoski!
Deleting tsf.data in directory C:\ProgramData\FLEXnet helped, Inventor started, works perfectly.
Thank you very much for the quick reply! Hope this helps others!
Administrator Productivity
