Installation & Licensing
Error installing ECSU 2014
2 REPLIES 2
promedical
279 Views, 2 Replies
Hello:
I hope I am in the right place. I tried all posible solutions to install my software with the same error:
2013/11/19:17:57:47	Gus	GUS-PC	Install	Autodesk Material Library 2014 - Base Image Library	Succeeded
2013/11/19:17:57:48	Gus	GUS-PC	Installing Autodesk Material Library 2014 - Medium Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Entertainment Creation Suite Ultimate 2014" SETUP_PACKAGECODE={89E85904-425D-43CB-89F5-6272C371394C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Gus\AppData\Local\Temp\_AIDE0E.tmp\Media.mst"
 2013/11/19:17:58:31	Gus	GUS-PC	Install	Autodesk Material Library 2014 - Medium Image Library	Succeeded
2013/11/19:17:58:32	Gus	GUS-PC	Installing Autodesk® 3ds Max 2014:  TRANSFORMS="C:\Users\Gus\AppData\Local\Temp\_AIDE0E.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/19:17:58:45	Gus	GUS-PC	Install	Autodesk® 3ds Max 2014	Failed	Installation aborted, Result=1603
2013/11/19:17:58:57	Gus	GUS-PC	Rollback	Autodesk Material Library 2014 - Medium Image Library	Succeeded
2013/11/19:17:59:10	Gus	GUS-PC	Rollback	Autodesk Material Library 2014 - Base Image Library	Succeeded
2013/11/19:17:59:31	Gus	GUS-PC	Rollback	Autodesk Material Library 2014	Succeeded
2013/11/19:17:59:31	Gus	GUS-PC	Rollback	DirectX Runtime	Failed	Failure is ignored, Result=1619
Made a new user full access etc etc.
I am runing an ASUS I7 8 core Windwos 7 PRO 16Gb memory with enough space in HD.
Any help will be really greatfull!!!
Gus
2 REPLIES 2
emily.xu
in reply to: promedical
Hi
Welcome to Autodesk Community!
Could you please check if this solution can help you?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
promedical
in reply to: emily.xu
Hello Emily:
Thanks for your answer. Yes! I did follow the solutions from the web. I was hoping more see if you guys can spot something in the log to give me a clue what is going on. REverything goes good Visio C++ .Net etc but whne if shows installing 3DS.Max is when everything rolls back.
I created a new user, I have change the HKeys permissions etc, has been two weeks :).
Gus
Administrator Productivity
