Hello:
I hope I am in the right place. I tried all posible solutions to install my software with the same error:
2013/11/19:17:57:47 Gus GUS-PC Install Autodesk Material Library 2014 - Base Image Library Succeeded 2013/11/19:17:57:48 Gus GUS-PC Installing Autodesk Material Library 2014 - Medium Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Entertainment Creation Suite Ultimate 2014" SETUP_PACKAGECODE={89E85904-425D-43CB-89F5-6272C371394C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Gus\AppData\Local\Temp\_AIDE0E.tmp\Media.mst" 2013/11/19:17:58:31 Gus GUS-PC Install Autodesk Material Library 2014 - Medium Image Library Succeeded 2013/11/19:17:58:32 Gus GUS-PC Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\Gus\AppData\Local\Temp\_AIDE0E.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/11/19:17:58:45 Gus GUS-PC Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2013/11/19:17:58:57 Gus GUS-PC Rollback Autodesk Material Library 2014 - Medium Image Library Succeeded 2013/11/19:17:59:10 Gus GUS-PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded 2013/11/19:17:59:31 Gus GUS-PC Rollback Autodesk Material Library 2014 Succeeded 2013/11/19:17:59:31 Gus GUS-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Made a new user full access etc etc.
I am runing an ASUS I7 8 core Windwos 7 PRO 16Gb memory with enough space in HD.
Any help will be really greatfull!!!
Gus
Hi
Welcome to Autodesk Community!
Could you please check if this solution can help you?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hello Emily:
Thanks for your answer. Yes! I did follow the solutions from the web. I was hoping more see if you guys can spot something in the log to give me a clue what is going on. REverything goes good Visio C++ .Net etc but whne if shows installing 3DS.Max is when everything rolls back.
I created a new user, I have change the HKeys permissions etc, has been two weeks :).
Gus
