I just had a similar experience with LDT2008 Companion. Every time I would
run the deployment from the computer I created the deployment on, which is
also the machine I had set up as a replacement license server. It would
install as a stand alone and ask for registration.
I finally created a deployment on my workstation and tried to deploy from
there. On my test computer the installation went fine. I then move the
deployment to the computer I wanted it to be on. It then installed as a
stand alone again. The only difference was what computer it was on.
So now the deployment is on my workstation because that's where it will run
from. I never spent the time to find out why. Hope this gives you some clue.
Allen
wrote in message news:5683838@discussion.autodesk.com...
I have just deployed C3D 2008 software suite. When opening C3D it tries to
verify license. It then brings up the prompt to continue trial or register
product. The odd part is that the LDD and Map companion recognize the
license and work just fine. Could the problem be in the deployment? Thanks
in advance for your help
