I have Autodesk Maya 2013 64bit installed on my machine and I uninstalled it and tried Maya 2014. I have never installed 2014 before but when I installed it, the installer only installed BackBurner, MatchMover, and the like and says that Maya 2014 is installed even though it is not. I cannot find Maya 2014 on my registry so I come here to ask help if what registry key/s should I edit/delete. tnx
Solved by dembkod. Go to Solution.
Use Microsoft Fix it to uinstall the program. Basically, if the system thinks the software is already installed, Fix It will 'fix it".
http://upandready.typepad.com/up_and_ready/2012/06/windows-the-basics-of-using-microsoft-fix-it.html
Hi David.Lau
Thanks for the link but I kinda have a problem. My Operating System(Windows 8.1 64bit) is not yet supported. But thanks! I will wait for my system to be supported 😃
Hello. You may be able to get past this phenomenon by deleting a specific reg key for Maya. If you delete this:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\D5CB8AF74EC73F24E8EA23FDB5BA357A
It may let the installer install over the remnants of the old install.
Thank you for taking part in our community!
Where would I find that file to Delete? I imputted it in the Command & Search Bar on Libraries, Nothing, Windows 7 64. Program was orriginally on one of my secondary SSDs
You will find the key in the windows registry via regedit.exe
Type Regedit into the search in Windows and you should find the program.
My i also suggest that you create a need community post regarding this if my recommendation does not help you.
Hi, I am using Autodesk Maya 2016. Can u help me out, which registery key, do i have to delete. I have tried Microsoft fix it and also deleted all folders associated name of Autodesk or Maya but nothing worked. I would be grateful if you help, which reg. key do I have to delete
Thank you
