• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    zdanielu
    AutoCAD LT 2011 - Silent Install
    4165 Views, 7 Replies
    10-11-2010 01:56 AM
    Does autocad supports silent install with no user interaction?
    I want to install the app in Deutch language, to include Design Review 2011, all features + the Service Pack( product update 1.1)
    How can i do that?
    Thanks.
    Please use plain text.
    Product Support
    Re: AutoCAD LT 2011 - Silent Install
    10-11-2010 02:30 AM in reply to: zdanielu
    Yes creating deployment image would be the best option; here you include Update 1.1( please use append option while creating image to add the update)
    http://docs.autodesk.com/ACDLT/2011/ENU/filesInstallLT/WS1a9193826455f5ff4e421d7d11bf108001d-5174.ht...
    Or you could script it as well; which would need the pre-requisites installed seperately.
    http://docs.autodesk.com/ACDLT/2011/ENU/filesInstallLT/WS1a9193826455f5ff4e421d7d11bf108001d-4f8f.ht...
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    Member
    zdanielu
    10-13-2010 01:09 AM in reply to: hashim.mundol
    Thank you for the script, i still need to manage to install the app in Deutch, is ther a language parameter? or how can i change the language.
    Product Support
    10-13-2010 01:22 AM in reply to: zdanielu
    The Languages are mentioned in the script
     de-DE = Deutchland German
    If you want the German version of the documents you can get it here (replacing ENU with DEU in the URL; this is applicable most Autodesk 2011 help files)
    http://docs.autodesk.com/ACDLT/2011/DEU/filesInstallLT/WS1a9193826455f5ff4e421d7d11bf108001d-4f8f.ht...
    Hashim Mundol
    Member
    zdanielu
    10-20-2010 03:20 AM in reply to: hashim.mundol
    many thanks,
    i have installed the application using this command, this is with no UI
    strInstCommandLine = """" & strCurrentDir & "\setup.exe" & """" & " /w /t /qb" & " " & "/Language" & " " & "de-DE" & " " & "/c ACADLT:" & " " & "INSTALLDIR=" & """C:\Program Files\Autodesk\AutoCAD LT 2011 de-DE\""" & " " & "ACADFIRSTNAME=" & """PC""" & " " & "ACADLASTNAME=" & """User""" & " " & "ACADORGANIZATION=" & """NAME""" and the parameters for the license
    Using this command allows users to click cancel installation, and "qb!" =  no cancel button is not working, is there another solution to hide the cancel button?
    Product Support
    10-20-2010 04:07 AM in reply to: zdanielu
     /q or /qn should be completely silent.
    if wish to see some progress bar you could try /passive along with /qb (i haven't tested these)
    Hashim Mundol
    Member
    05-23-2012 02:40 AM in reply to: zdanielu
    what parameter can i pass to  the setup to remove the desktop shortcut permanently?
    Product Support
    05-23-2012 12:03 PM in reply to: zdanielu
    It would be best to use Deployment image to control these behaviour.
    if you really want MSI parameters. (I havent tested these)
    Please try
    ADSK_DESKTOPSHORTCUT_1=0
    and
    ADSK_DESKTOPSHORTCUT_2=0
    Hashim Mundol
