Does autocad supports silent install with no user interaction?
I want to install the app in Deutch language, to include Design Review 2011, all features + the Service Pack( product update 1.1)
How can i do that?
Thanks.
Yes creating deployment image would be the best option; here you include Update 1.1( please use append option while creating image to add the update)
Or you could script it as well; which would need the pre-requisites installed seperately.
Thank you for the script, i still need to manage to install the app in Deutch, is ther a language parameter? or how can i change the language.
The Languages are mentioned in the script
de-DE = Deutchland German
If you want the German version of the documents you can get it here (replacing ENU with DEU in the URL; this is applicable most Autodesk 2011 help files)
many thanks,
i have installed the application using this command, this is with no UI
strInstCommandLine = """" & strCurrentDir & "\setup.exe" & """" & " /w /t /qb" & " " & "/Language" & " " & "de-DE" & " " & "/c ACADLT:" & " " & "INSTALLDIR=" & """C:\Program Files\Autodesk\AutoCAD LT 2011 de-DE\""" & " " & "ACADFIRSTNAME=" & """PC""" & " " & "ACADLASTNAME=" & """User""" & " " & "ACADORGANIZATION=" & """NAME""" and the parameters for the license
Using this command allows users to click cancel installation, and "qb!" = no cancel button is not working, is there another solution to hide the cancel button?
/q or /qn should be completely silent.
if wish to see some progress bar you could try /passive along with /qb (i haven't tested these)
It would be best to use Deployment image to control these behaviour.
if you really want MSI parameters. (I havent tested these)
Please try
ADSK_DESKTOPSHORTCUT_1=0
and
ADSK_DESKTOPSHORTCUT_2=0
