Hi
I've also a problem with the symmetrical stretch.
See .dwg as a attachement.
As you can see this is for instance a rectangular or a square steel beam.
Stretch in the length that is not a problem.
When I stretch in the heigth for instance height = hoogte 150 mm. I measure 180 mm.
How is that possibel?
Kin regards
Vanden Borre Gilbert
@gvborre change the basepoint of the vertical stretch to MIDPOINT. See the image below
Howard Walker
Hi hwalker
That is kind of you.
Yes, that is the solution.
Kind regards
In attachment you can find the solution.
