Hi all,
I remember a tutorial that explained how to utilize a scale action; but, you could use grips on either side (left or right) of the block to change the scale (from a set point parameter) and you drag the grip it would snap to preset increments like the door example.
I can't find the tutorial and need to refresh my memory. Can anyone point me in the right direction?
Thank you in advance for any assistance.
Solved by jarredmonday. Go to Solution.
Google.
Sorry for the terse answer but any tutorial you need you will find thru Google easier than here.
Youtube is pretty lousy with tutorials as well.
Or give it a go and post a Block for us to see and critique. Do a little fishin' as it were.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Yeah I tried that first even searched through my list of links.
I just supposed that someone here had seen it too.
See my attached drawing to see what needs to be done.
Add a Linear Parameter and attach the Scale action to it. Next you want to highlight your Parameter and change to "Increments" in the Properties window. You will also need to go to the Action Properties and change the OverRides to "Dependent" and adjust your "Base offsets" to your desire.
Quite simple really.
