Yes, you can do that.
The trick is to make sure that the attributes positions are LOCKED. I
have no idea why, but it works.
Now, you may wish to be able to move the attributes around in the
block by grip editing. A workaround to this is to include a move
parameter/action set to simulate this.
I've attached an example (a hospital wall corner guard)
cheers
Peter
On Thu, 23 Mar 2006 01:01:23 +0000, C Witt
wrote:
>Ok, what I want.. a DB with 2 VS's:
>VS1 - has 2 attributes (tags "detail-1" and "drawing")
>VS2 - has 1 attribute (tag "detail-2")
>How (if possible) can I set up the block so that if VS2 is active, the
>tags from VS1 "go away".. I'm talking about in the attribute editor as
>well as visually. (same goes for if VS1 is active)
>Anyone?
