I accidentally deleted the Basepoint parameter from the Block Authoring Palettes. Is there any way to recover that parameter?
Solved by edwin.prakoso. Go to Solution.
What is your AutoCAD version? In attachment is parameters palette for AutoCAD 2015. You can import it to authoring palette. But you need to extract the zip file first.
The xtp should be the same for older AutoCAD version. But if it doesn't, try to export the palette from other computer that has the same version as yours. Then import it to your AutoCAD.
Cheers,
Edwin Prakoso
Is there any option to get back parameter sets? i mistakenly deleted linear stretch in parameter sets.Please help i am using autocad 2018 .Thanks
You can easily create your own parametersets.
For demonstration I deleted my linear stretch and created a new one.
HTH
Jürgen Palme
