I am creating a wall mounted junction box dynamic block and I'm running into a problem. I'm using an alignment parameter to rotate the block based on the rotation of the wall it is being placed on. Unfortunately, the "J" in the center of the circle will not stay with zero degrees rotation like it would if you lock the attribute and rotate with a normal rotation command. It seems like the "lock attribute" option does not jive with the alignment parameter. Any ideas?
