Good Day All
I recently created a Symbol catalog in design review 2013. every thing works perfect except i cant rename the symbols in this catalog.
Any Ideas. PLZZZZ
Solved by cblocher. Go to Solution.
From the Symbols button drop-down list, click Manage Catalogs.
Select the one you want to rename, click Rename and type the new name you want.
FWIW, you cannot rename an individual symbol in a symbol catalog once it has been created.
Hope it helps,
C.
hi Chris
That helps a bit. can we put it on a wish list for te next design review to rename each symbol.
Thanx
Gladly!
Added "Rename Existing Symbols" to the wishlist.
Best,
C.
Hi guys.
I know this is an old thread, but I've worked out how to do this.
Once you have imported your catalog, export it as a .sym file.
Open that file in Design Review (you'll need to change to 'all files').
Rename the sheets - there is one sheet per symbol. This will be your symbol name in the catalog.
Save the file as a .dwf.
Then use the 'Create Catalog from DWF...' command to import them.
You'll need to add the name of your catalog again.
I did this in Autodesk Design Review 2013.
-Matt
