I'm trying to export my DWG file to DWF but running into some problems.
I use the export routine in TrueView but get the error message 'There were no plottable sheets in the current operation.' Is there certain things I have to do to the drawing to make it export?
If I open it in Design Review it is just a blank canvas.
I can plot the drawing and save it as a DWF but then I lose all layer information.
Alex
Are the export parameters the same as the plot parameters? It would appear they differ base on your description alone.
They are the same, there's not really much to change. I've got them both zoomed to extents and pen assignment is DWF Virtual Pens.
Alex
Been playing around with it but still cannot get it to export it because of the error. I can get it to convert if I use AnyDWG so there must be something plottable in it. Any ideas?
Alex
Hi!
Have you found a solution?
Because we have the same issue - can't export dwg to dwf (but in AitoCAD 2014).
And a little note: dwf could be created after switching from model to layout.
But couldn't be saved because of other error. (we have had Autodesk Design Review'13 installed already)
OK, everything is working and now I can create DWF... but only from Layout.
Why?
I just try to understand, could this error ('There were no plottable sheets in the current operation' in Model) cause the job-processor error ('Unknown error during publishing')?
If not - OK, I'll look in other side.
