Export form Inv to Simulation problem
Dan_Margulius
Advisor Advisor
Dan_Margulius
When I export the model to Simulation parts are missing. See pictures.
What can be done?
Dan
John_Holtz
Autodesk Support
Autodesk Support
That's interesting Dan. I have no idea why some parts do not come in. (Actually, Simulation knows there are 6 parts during the import, but only brings in the 3 like you show.) I will check with our developers to see if they can find the cause of the problem.
It looks like the model is not a native Inventor model. Do you know what software was used to create it? Ideally, it will be a package that Simulation can open directly and therefore bypass any other issues.
If not, I used Fusion to open the Inventor assembly, and then transferred the Fusion model to Simulation. Just remove the dummy .txt extension, and then you can open the archive (.ach) with Simulation.
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Dan_Margulius
Actually these are demo files from Simulation CFD. I dont know from which CAD package they come.
The export from INV to MP really improved in 2013 version and is much faster. I was suprised to see this problem on such simple model
Thanks for the file
Dan
