- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there! I have two questions regarding boundary conditions and loading when using Autodesk Simulation.
1. I primarily design components that rest on the top surface of a piece of machinery and can end up being rather complex. Due to my assemblies being located on the top surface, I've been creating large solid fixed blocks below my part and using surface contact between them to prevent negative Y movements. However, this is computationally heavy and it has led me to wonder if there is such a thing as one-directional boundary conditions. In other words, is there a way to fix the bottom surface of my machinery to be free to move in all directions except in the negative Y direction?
2. If I know how much displacement is applied to a part, can Simulation calculate the resulting stress? For example, if I have a cantilevered beam that I know has deflected 1" on the free end, is that a load case I can apply and have displayed resulting stress?
Many thanks!
