- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Ran across this issue from a pick list set up to be a link to the picklist WS records hyperlinks to the wrong revision of the item.
In my RFQ workspace I have a grid with a picklist field from my Items & BOMs workspace. In the RFQ the item descriptor shows the correct active record (REV2) but when you select the hyperlink it takes you to the Superseded record.
I believe the revison to the item record occurred before the item was added to the RFQ grid, based on the change log of the RFQ and the change order that updated the item.
I would not have noticed this discrepency accept that in this instance the key field of the Item Descriptor was changed by the revision.
See attached screen shots for details
