Replace styles in Drawing
Rene-J
Rene-J
Hi
I have some styles I will like to replace in some drawings
but how? I cant find any function to do this.
Do I missing some thing ?
Dim oIDWStyles As Inventor.DrawingStylesManager
 Set oIDWStyles = oDrawDoc.StylesManager
 Dim oldstyle As style
 Dim Newstyle As style
   For Each oldstyle In oIDWStyles.Styles
     If oldstyle.Name = "Old style" Then
       '  Debug.Print oldstyle.Name & " : " & oldstyle.InternalName
        For Each Newstyle In oIDWStyles.Styles
          If Newstyle.Name = "New style" Then
            'Debug.Print Newstyle.Name & " : " & Newstyle.InternalName
            End If
        Next
        'How to replace oldstyle with newstyle
         'oldstyle = Newstyle
     End If
   Next
René J
cmines
This worked for me:
' Create the parts list and set a reference to it.
    Dim oPartsList As PartsList
    Set oPartsList = oSheet.PartsLists.Add(oDrawingView1, oPlacementPoint)
    oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("PARTS LIST PART")
Hope this helps.
Chris
jdkriek
You can rename it, delete it, set another style as the object default, but no direct replace that I know of.
If you set the new styles as object defaults, then you could change all elements to the active standard.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
cmines
UGHHHH....I swear I read "parts list style" the first time I read your post!  Thats what I get for responding before I've had some caffeine!
jdkriek
Get some coffee, it will be alright - for a Friday 😉
Jonathan D. Kriek
Rene-J
Thanks Jonathan
Finally I got the time, to look at your suggestion.
I'm sorry I have not commented earlier, I've been on vacation.
I thought there was an easier solution.
René J
