But I like the magnet effect.
I am pretty sure it is linked to the View > Shade problem somehow. The
shade mode switches on by itself after I zoom a few times. I can tell it
has happened because all of a sudden some lines aren't selectable when I
click on them. For some reason this is a buggy thing in ADT that happens.
A ghost image is created just off to the side of the real objects and that
becomes the place that has to be clicked to select the item. So when I
click on something and it is not selected, then I know the shade mode has
just turned on. I go over and click on 2D wireframe and then the image
changes a tiny bit, and I can select objects again.
I'll give your magnet idea a try. darn it....It happens a lot working thru
the viewport. I might have some conflicting software installed so will be
checking that angle too. Another weird thing going on is that my I.E.
doesn't load when I click on it the first time. It sort of flashes like it
is going to open, but nothing happens, and then if I open it a second time
it opens right up with no evidence of a problem. This is abouta week old
now.
Jack
"Arthur H. MacLeod"
wrote in message
news:680161177C64209C2AE60F643DFB8656@in.WebX.maYIadrTaRb...
> Jack,
> What happens if you go to Tools> Options > Drafting and unselect the
magnet
> in autosnap settings? I don't know about the shade mode problem. On the
> hatch problem, I'm curious are you hatching in model or paper space? I ask
> because I get bizarre behavior when inserting Ole objects in paper space
but
> not model space.
> Arthur
