Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
92 Views, 3 Replies
status bar
can someone please tell me how to get me status bar to appear on my screen.
It seemed to just disappear. Do you know what I did? I cannot get the
SNAP, GRID, ORTHO,POLAR,OSNAP............ buttons on the bottom of the
program screen.
thanks in advance
K Anderson
3 REPLIES 3
Are you sure the wondows task bar isn't covering it up? If you minimalize
the ADT window, are they visible? Are you saying ADT simply stops at the
bottom of the command line?
"keene" wrote in message
news:E031F5015AD111FF6CF1D13C4AECB2EB@in.WebX.maYIadrTaRb...
screen.
> program screen.
> thanks in advance
> K Anderson
Is AutoCAD/ADT window maximimized? If not, did you slide the window down so that the task bar or a floating toolbar is covering it? I do not see anything in the Options dialog that would allow you to turn off the status bar.
David Koch
Member of the Autodesk Discussion Forum Moderator Program
If it is behind the Windows taskbar(likely), either temporaily increase the screen res. and resize the ADT window up a hair, or right-click on the taskbar> properties> autohide, which is how I keep mine. Bob
