- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I would like to plot a drawing whereby I can set the plot styles on all layers to monchrome, and then select a couple of layers to plot in their respective colour. I expect that I should be able to manage this from the layer properties manager, however the column for 'Plot Style' will not allow me to make any alterations. I read somewhere that I should try to change the plot style designation:
When I try to toggle between the two plot designations using command 'CONVERTPSTYLES' it seems to error..... or at least it'll not allow me to select from the suggested saved plotstyles.
I have experimentend with, and created CTB's and STB's and have had no luck. (I think I have gathered a reasonable understanding of what the two styles SHOULD do)
Does this software have a bug? Or more likely..... What am I doing wrong.
Hope somebody can help.
Ohhhh,
Currently running Architecture 2007....
But imminently awaiting BRAND NEW Architecture 2012 Package
