Hiya. I've been working on a drawing autocad for mac 2013.
I want to scale my drawing by 2. Every time I try it acts as if it has worked, but the physical size hasn't changed at all. At first I thought it might need a larger scale factor to see the difference, but no matter what the value (even 0.5), the dimensions aren't changing.
Does anyone have any ideas what's going on? I've used the programme to scale before and it has worked. I also tried the drawing on another computer, but it made no difference
Solved by maxim_k. Go to Solution.
I'll send you the drawing.
it's part of a larger drawing, but this is what I need to scale:
Almost all of objects in your drawing are constrained with each other (parametric constraints feature). So when you try to scale all objects in this drawing you (as I) should get this at the command prompt:
Command: SC
SCALE
Select objects: Specify opposite corner: 268 found
Select objects:
Specify base point:
Specify scale factor or [Copy/Reference]: 2
One or more constrained objects cannot be resolved.
In order to see all constraints you have to select "Constraint bars -> Show all" from Parametric menu.
In attached file I deleted all constraints, an now it is "scalable".
Maxim
Thanks a lot..it's perfect.
What did you do to delete all the constraints though? I went into parametrics, constraints bar, show all, but nothing changed on my drawing.
In fact, I don't even know what constraints are I'm afraid
@Anonymous wrote:What did you do to delete all the constraints though? I went into parametrics, constraints bar, show all, but nothing changed on my drawing.
If you did this with drawing I've send to you - then there are no constraints in it, I already deleted them all.
If you will try to "Show all constraints" in your original drawing, then you should see:
@Anonymous wrote:In fact, I don't even know what constraints are I'm afraid
You can start to learn about Parametric Constraints in AutoCAD Help here:
http://docs.autodesk.com/ACDMAC/2013/ENU/filesAUGMac/GUID-F873DE3A-0F12-4A58-B35E-0BC5C98A7F35.htm
Maxim
