Hi doe anyone know how to apply material to one side of a wall with out it being applied to the interior. I am trying to apply brick to the outside of wall but it also goes to the inside.
Solved by 708Designs. Go to Solution.
Solved by maxim_k. Go to Solution.
If the wall in your drawing created as 3D Solid - the easiest way is to hold Ctl key while you apply material, then material will be applied only to the face you pick (interior in your case).
Maxim
