- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
FATAL ERROR: Unhandled Access Violation Reading 0xfffffff8 Exception at efdd241ah
Crashes on start up..... Repaired - no change Re-installed - no change
When it initially crashed, I renamed the project file I was working and added "bak" to it, in case it was causing the issue.
ACad / revit / ASD all start up without an issue, it is JUST P3D I am currently unable to work. I put in a ticket, but does anyone have a suggestion aswell? |
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
