Factor of 25 strongly suggests that the drawing was started as metric and
acadiso.pat is being used instead of acad.pat.
Dave Byrnes / Vancouver, BC
Autodesk Discussion Group Facilitator
"kwmahan" wrote in message
news:2337458.1096920237042.JavaMail.jive@jiveforum1.autodesk.com...
> Working on hatches, using LINE pattern, in a drawing file created in
AutoCAD 2000, now using AutoCAD LT 2005. New hatching, done in LT, appears
at a much larger scale (ie larger line spacing by factor of 25). Both old
and new hatches indicate the same scale factor in Properties. Match
properties command does not have an effect on spacing. Is there another
variable controlling hatch scale?
