Hi
Can any one help me, when I create a block in 2010 LT it will show up if I browser to the file location, however if I try to place a block AutoCAD does not see it and I cant place it.
Can you re-write your post, and use AutoCAD command names instead of terms like "place", "create" and "show up if I browser"?
If you change your mind, you are welcome to come back and finish the posting: just use correct technical terms if you are seeking technical assistance with technical software.
That's the second new member this week to condescend.
Tough audience.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Like the man said what are you trying to do?
INSERT?
XREF?
Be specific so we don't have to flounder with answers.
We are busy too there Sparky!
No worries, when folks are in a bind they can get easily flustered.
I suspect the OP figured out how to "find" the block using either INSERT or ADCENTER (or moved it to a central lcoation).
