We have AutoCad LT 2012 version. We encounter fatal error when we save the drawing. we cannot finish our job because everytime we save our work it will show a messsage FATAL ERROR. Can anyone help me regarding this issue/error message.
Thanks.
JM
Solved by braudpat. Go to Solution.
Hello
A few ideas:
1) Have you installed SP 2 for ACAD LT 2012 ?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19501802&linkID=9240818
2) Have you the probleme for ALL DWGs or only a few ?
If a few : please open these DWGs in Recover mode and re-save them ...
And re-test !
3) Have you the probleme only when you save DWGs on Network ?
If YES and if your Server is a Windows Server 2003/2008/2012 :
- please DIsable "Indexing File Search" on the Server volumes
- and check that the "Off Line Mode" is Disabled on the Server
Maybe you will have to reboot the Server ...
Bye, Pat
Patrice BRAUD
I installed the service pack 2. I think now its working good. no more fatal error message we receive when saving drawing. Thanks for your help.
JM
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
