Autocad Lt 2011 This error message:FATAL ERROR:Unhandled Access Violation Reading 0*20ff6f9b8 Exception at 772efe06h
Do you have that can help.
thanks
No results in the KB.
Do you know what you are working on when this happens?
Anything change on the computer recently?
Reg Cleaner?
Win update? Specifically a .NET update
New programs?
Virus update?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
We get this error often but only on the machine that has a known flaw in the memmory (ram) there is a stick of ram that came with this computer that has tested faulty. We beleive (not positive yet) but wethink that the error message is related to the memmory crashes due to the faulty stick of RAM. Our solution is to replace the bad memmory module, which is currently on order. I would suggest running a memmory test on the computer that is generating the error code and/or checking to ensure that your current memory specifications on your computer match the required memory recomended for the autodesk aplication.
Best of luck,
Boston
