AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
EXPORTTOAUTOCAD
22 REPLIES 22
Message 1 of 23
Charles_Shade
4150 Views, 22 Replies
EXPORTTOAUTOCAD
I'm trying to use this to knock a drawing back so the engineer can see the Multileaders.
He's on LT 2000 and communication of the drawing file can be problematic.
If I've read the (of little)Help file correctly I should be able to enter 2000 in the Format selection and have a 2000 file.
This is returning Invalid option keyword when I try.
What is the proper Format?
22 REPLIES 22
Message 2 of 23
Hi, not to sure about typing in entry but if you have dynamic input on it gives you a dropdown where you can just click on 2000
Message 3 of 23
Not seeing that and I use Dynamic input.
Message 4 of 23
When you click on format another dropdown should come up
Message 5 of 23
Nope that is not there but at least I know I'm not missing something. Well I am but not mentally (okay well that too) just in the program.
The other options from the main menu dropdown will open and offer another option or two but not Format.
I must have a glitch in my install somewhere.
Message 6 of 23
Not sure if it matters or not but I'm on my desktop, not my laptop so I'm using full autocad right now. Maybe someone else can check to see if thats why I get the option and you don't.
Message 7 of 23
pendean
in reply to: Charles_Shade
>>>...This is returning Invalid option keyword when I try....<<<
What does that mean exactly?
Watch the command line as you type (LT or full AutoCAD, desktop or laptop):
-EXPORTTOAUTOCAD (there is a dash in the command name)
FORMAT
2000 (or if you prefer, R14, just don't type R2000)
PREFIX (I like to identify the new file, like R2000)
<ENTER> and whatch where the new file goes.
Message 8 of 23
Charles_Shade
in reply to: pendean
I mean this:
2000, R14, whatever, nothing is recognized nor are there dropdown options when clicking on Format from the first menu in this Command
Message 9 of 23
AcadAdamLT
I got the same problem when trying to replicate.
after format it prompts me for file format, won't accept anything i type.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
Message 10 of 23
Charles_Shade
in reply to: AcadAdamLT
Adam - Do you have SP1.1 installed?
Message 11 of 23
I wonder if it's just a 2013 bug in LT. I've got 2012 LT and it worked fine. It also worked in 2013 full.
Message 12 of 23
pendean
Share the file?
Message 13 of 23
Charles_Shade
Happens on the blank drawing as well when I open CAD.
Message 14 of 23
pendean
Your file seems to contain many undefined 'shape' objects (and I did not have all of your fonts), but the command went through. Too big to attach: http://wikisend.com/download/365178/R200012-078A-2-11-13.zip
Message 15 of 23
Charles_Shade
Where did you "view" the shape objects? Not sure what to look for
Nothing but Dynamic Blocks and lines.
The Hatches are mostly from Hatchkit
Message 16 of 23
pendean
That's what the command reported as it was converting the file.
Message 17 of 23
Charles_Shade
AUDIT reported no errors
I had previously run the closing Macro we did over on the AUGI Forum that Purges and RegApps and all so it should have been clean.
LT starts here to a blank drawing file. Layer 0, all Styles are Standard; just OOTB stuff.
The Command does not work on that either.
Time to let Autodesk work off my Subscription payment. Smiley Wink
Message 18 of 23
pendean
Your file was very clean, I tried all that too 🙂
Message 19 of 23
AcadAdamLT
In reply to your earlier post, yes I'm running SP1.1.
The problem persists in all my drawings, blank or not.
AutoCad LT 2016
Message 20 of 23
steven-g
Just as confirmation, same problem here 2013LT no service pack, I just get the invalid input
”Boost
