Will AutoCAD 14 work with Windows 8 when it arrives this year.
Solved by pendean. Go to Solution.
Solved by Charles_Shade. Go to Solution.
Those who know cannot say and those that say do not know.
It will not be official until the Version is released assuming that there is a 2014 even being released...
I would suspect that it would be compatible with Win8.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
It's very likely since Windows 8 is out in public that any new software from Autodesk and the other big producers, unless they really want to commit sales-suicide.
Hello
You know that a new Relaese of AutoCAD will be release this Spring (as each year) ...
Could you imagine that Autodesk will not support Windows 8 ?
I can bet ...
Bye, Patrice
Patrice BRAUD
is there any luck to install simulation CFD on my windows 8
I dont have windows 7 and I need simulation CFD.
what should I do ?
CFD?
Autodesk Simulation CFD: you are in the wrong forum for one this, second you can find out for yourself by reading the Windows 8 Support document in the right column of this webpage you are reading this second over here>>>>>>>
