You can set the
onclick=alink_PSLTSCALE_SYS_423842.Click();>PSLTSCALE system variable to
maintain the same linetype scaling for objects displayed at different zoom
factors in a layout and in a layout viewport. For example, with
class=SmallCaps>PSLTSCALE set to 1 (default), set the current linetype to
dashed, and then draw a line in a paper space layout. In the layout, create a
viewport with a zoom factor of 1x, make that layout viewport current, and then
draw a line using the same dashed linetype. The dashed lines should appear to be
the same. If you change the viewport zoom factor to 2x, the linetype scaling for
the dashed line in the layout and the dashed line in the layout viewport will be
the same, regardless of the difference in the zoom factor.
With PSLTSCALE turned on, you can
still control the dash lengths with
onclick=alink_LTSCALE_SYS_423844.Click();>LTSCALE and
onclick=alink_CELTSCALE_SYS_423844.Click();>CELTSCALE. In the following
illustration, the pattern of the linetypes in the drawing on the left has been
scaled to be the same regardless of the scale of the view. In the drawing on the
right, the scale of the linetypes matches the scale of each view.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"kn6398" <Does
href="mailto:kray.nguyen@cingular.com">kray.nguyen@cingular.com> wrote
in message
href="news:f0fbbd8.-1@WebX.maYIadrTaRb">news:f0fbbd8.-1@WebX.maYIadrTaRb...
anybody no why dashed line doesn't show in model layer but will show in layout
layer?
"paddy666" <Well
href="mailto:james.murphy@wheatleys.net">james.murphy@wheatleys.net>
wrote in message
href="news:f0fbbd8.1@WebX.maYIadrTaRb">news:f0fbbd8.1@WebX.maYIadrTaRb...
could you possibly help me with my problem, I have opened a new drawing with a
scale of 1:50 so I’ve set the PSLTSCALE to '0' and LTSCALE to 350 but the line
type is not coming out right, if I do the same in R14 it works fine.
Just to let you know I always do this on all my drawings and it works fine
till now.
Is there a global variable that I don't know about?
Many Thanks
Jim
"psmith610" <Did
href="mailto:psmith@ccsllc.com">psmith@ccsllc.com> wrote in message
href="news:f0fbbd8.3@WebX.maYIadrTaRb">news:f0fbbd8.3@WebX.maYIadrTaRb...
you ever get this resolved? I am having the same problem. Using the advice
found in this forum, I am able to change the scale so that the dashes show in
either the layout or model. But, I cannot get them to show correctly in both.
Any advice?
