I'm using AutoCad LT and when I use any command that requries me to select the object, it wont show what i have highlited. For example if I have an object that I need to move, if start the move comand select the object I want to move then select the basepoint it will not show me where I'm moving/placing the object. Is there some kind of default/option in autocad that prevents that from happening? I've never had this problem before using my full version. Please can someone help me!
