When I double click on a dynamic block the block editor does not open the Help window opens up instead.
BLOCKEDITLOCK is set to 0
PICKFIRST is set to 1
I have looked through the forum and have tried the two solutions above, restarted Autocad but to no avail.
I was able to open BLOCKEDITOR by double clicking the other day but now can only open it from the command line with BEDIT command. I am trying to build my dynamic block knowledge so am not too familiar with this part of the software. I may have inadvertently changed a system variable.
Can you help?
Solved by braudpat. Go to Solution.
Hello
Welcome to the Autodesk/AutoCAD Forums !
A few ideas "in fast mode" :
PICKFIRST = 1
PICKADD = 1
DBLCLKEDIT = 1
Bye, Pat
Patrice BRAUD
I have a problem with one drawing created by someone else in a non AutoCAD program; Normally I right click on a block and it opens the block editor, but in this drawing, some blocks will do this and others just open the command line edit. The commands work fine in other drawings, it's just this one someone else has created. I'm baffled why it works for some blocks and not others in the same drawing! Any idea what to do to get them all to open in the block editor window? Running AutoCAD LT 14. Pickadd and Pickfirst are set to 1. Blockeditlock is 0.
Thanks in anticipation
