Hi to all, I use Autocad LT 2002 on WindowsXP; a few days ago the license of Norton Antivirus expired, so some days without protection are passed.
However today i installed the Norton Internet Security 2012... but now after a few commands, Autocad LT 2002 crashes with the "Internal Error: Gedit 3" message.
I already tried the patch SP1 (Italian), but the error keeps going out.
Thanks in advance.
Well, i tried to use the Gedit 3 patch but did not work, (i can't install English Locked and English Unloked version of the SP1)... but using the file that Willfogg posted on this thread works well.
http://forums.autodesk.com/t5/AutoCAD-LT/AutoCAD-LT-2002-Installation-on-Windows-Vista/m-p/2641223
It might be to help for someone.
Thanks anyway
Restore the OS to prior to the Norton install.
If that works do as suggested above and dump the Norton.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
@Anonymous wrote:Any recommendations on Security Software known to be compatable with ACLT?
AVG ~ http://free.avg.com/us-en/homepage
AVAST! ~ http://www.avast.com/en-us/index <------ My fav.
HTH
DJ
[edit]
... and they're FREE!!!!
[/edit]
microsoft also has a free antivirus program
DarrenP
@DarrenP wrote:microsoft also has a free antivirus program
The OP might want to read >>>this<<< first and see if it applies to them.
did you read this whole thread?
a solution was posted
DarrenP
Drop the Norton products.
Upgrade LT to a current release.
Two known solutions.
I replaced my Norton Antivirus program with VIPRE last night. I am still getting the GEDIT 3 error. I also received it in the iterim between removing Norton and installing VIPRE. I don't think Norton is the problem.
Did removing Adobe fix the problem. because I am having the same problem with the GEDIT 3 after having my computer fixed and the repair company removed AVG and installed Norton.
Michael
