I am trying to set up my template for architectural drawings. I would like to use annotative text and dimensions and leaders. I have selected a font and am trying to set my Paper Space text height to 3/32" so all drawings in all scales have text of 3/32". When I type in 3/32" it returns a value of 1/8". How do I get it to recognize the 3/32" value. Also if I save this in the dwt file will it always be set for this?
Solved by Charles_Shade. Go to Solution.
Go to UNITS and change the Precision value to 1/32 instead of 1/8.
2. Yes
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Are you using MLEADER or QLEADER?
From the Dropdown; Format; MLeader or fromt he Command line: MLEADERSTYLE make sure the text height is set to 4-1/2".
If you have defined a height for this Text in the Textstyle manager this box will be grayed out.
(check the box on the bottom right of the post )
Post a DWG file with the problem MLEADER in it, add instructions inside the fil to shwo what you want vs. what you got.
On the bottom right of each post in the Thread is a place to select the Mark as Solution.
Doing this step will allow the post to show how it was Solved and will provide the telltale Green Check.
